ls3 cam in 5.3
Old 09-07-2012, 02:10 PM
camminls2's Avatar
Default ls3 cam in 5.3
what do you have to change to run a ls3 cam in a 5.3? and is the cam good for turbo?
Old 09-07-2012, 02:11 PM
litle88's Avatar
Why does it have to be that cam?
Old 09-07-2012, 02:52 PM
camminls2's Avatar
i was gonna buy it, for the motor i get
Old 09-07-2012, 02:53 PM
camminls2's Avatar
it dosent have to be that cam if you know fo a bad **** cam for boost, sorry i miss read that the post, let me know
Old 09-07-2012, 08:30 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
The LS3 cam is essentially a LS1/LS2 Z06 Vette cam.... with the exception of it being a single bolt version.
It does not have the cam position sensor at the rear of the cam like the early 5.3.
If your 5.3 is 07 & newer it should work as you already have a single bolt cam.
It will not fit early 5.3's
I have a 2011 Camaro cam, bolt & gear with 12miles on it if interested.
Quick Reply: ls3 cam in 5.3
