instaling rear coolant crossover pipe
Old 09-08-2012, 10:10 AM
RIDYT's Avatar
Default instaling rear coolant crossover pipe
02 T/A WS6
Is the only way to remove coolant plugs from rear of heads and install coolant crossover pipe, is to drop tranny x-member and lower tranny? That is the only way i see doing.
Old 09-08-2012, 01:24 PM
sjsingle1's Avatar
did you even try to remove the manifold????????
Old 09-08-2012, 02:57 PM
JaYZeig's Avatar
you can do it however way you want..
its not hard to get the intake plenum off, youll
be happy you did. then youll have all the room
in the world.
Old 09-08-2012, 03:00 PM
msydow's Avatar
just take the intake off. it takes 10 minutes.
Old 09-08-2012, 03:08 PM
RIDYT's Avatar
Removing intake was my 2nd choice, was trying to avoid purchase of gaskets, and possiable broken are stripped bolts, and the remove & install of other components. But more likely not to have leaks from the coolant pipe by removing intake. Thanks for the advice.
Quick Reply: instaling rear coolant crossover pipe
