Royal Purple Purple Ice coolant additive?
Old 09-09-2012, 09:19 AM
Restricted User
LSPowered's Avatar
Question Royal Purple Purple Ice coolant additive?
Has anyone used this & seen any real temp difference?
Old 09-09-2012, 03:35 PM
sjsingle1's Avatar
a 160 t-stat and a LT1 rad......is waaaaay better than any snake oil.......and i live in TEXAS
Old 09-09-2012, 03:44 PM
mikh338's Avatar
i just watched them test this on horsepower tv this morning. from their results at operating temp and idle it stayed around 10-15 degrees cooler and same as for a drive. they simulated the drive on their dyno i cant remember how long of a drive but it was supposed to be as if you were driving up hill for 20 miles or 20 minutes i cant remember exactly. but it stayed 10-15 degrees cooler as well. these tests were all done with straight water in the radiator and 2 bottles of that royal purple ice additive. seems like it works!!
Old 09-09-2012, 04:08 PM
LS6427's Avatar
If you try it....use the two bottles of RP Ice.....half jug of whatever coolant you like......the rest water.
It probably works.
Old 09-10-2012, 12:17 PM
Save the manuals!
wssix99's Avatar
I heard that if you pee in the radiator, the same thing happens.
As sjsingle1 points out, there are more reliable mechanical methods to bring the temperature down.
Quick Reply: Royal Purple Purple Ice coolant additive?
