Faint tick at 1500-1600 rpm
Old 09-10-2012, 02:36 PM
its turbo time's Avatar
Default Faint tick at 1500-1600 rpm
My car lightly ticks at 1500-1600 rpm. I've never really noticed it till now, but it seems to be on the driver side.
Is this the "GM tick" I've read about?
It has royal purple in it now, thinking about going back to pennzoil platinum to see if it fixes it.
Old 09-10-2012, 02:38 PM
I need a gauge for that
Atomic's Avatar
Sure its not an exhaust leak?
Old 09-10-2012, 02:50 PM
I guess it's possible, I wish I had a better ear for hearing the difference
Old 09-10-2012, 02:55 PM
Atomic's Avatar
If you can, put your hand around the exhaut ports and see if you can feel air puffing out and/or look for any soot poking out near a port.
Old 09-10-2012, 03:02 PM
On the head right?
Old 09-10-2012, 03:37 PM
Atomic's Avatar
It could be anywhere in the exhaust, but I suspect the flange has loosened off the head some and is leaking right at the gasket around the port.
Old 09-10-2012, 03:59 PM
427zm's Avatar
How many miles are on the motor? From what I understand, in higher mileage LS motors sometimes the oil pump gets weak and should be replaced. Once, this is done, the "tick" goes away. Basically, the top side of the motor is just not eating enough oil at lower RPM's.
Old 09-10-2012, 04:57 PM
The motor has about 80k
It has real good oil pressure.
I'll check for leaks tonight
Old 09-10-2012, 10:43 PM
Broke a header bolt!
Quick Reply: Faint tick at 1500-1600 rpm
