MSD 2Step VS Catalytic converter?
Old 09-16-2012, 12:19 PM
alexus6798's Avatar
Default MSD 2Step VS Catalytic converter?
Not sure if this is the correct section so move it if need be. My question is, If I install the plug and play MSD 2 step on my Firehawk, would it ruin my Cats? I heard that when activated the unburnt fuel will kill the cats. Any truth to this?
Old 09-16-2012, 12:40 PM
Old Geezer's Avatar
A good chance they'll get "toasted". Eventually, the brick will be either melted, or melted and blown into chunks....
Old 09-16-2012, 01:11 PM
alexus6798's Avatar
okay, thanks for information. I just hope I don't run into problems passing inspection if I decide to to ORY...
Old 09-23-2012, 09:57 AM
VodeAn's Avatar
Make a y pipe that you can swap out with lots of cats in it. Use v-band clamps or slip connectors to make it quick and simple to swap from "off road" to "street" ;-)
Old 10-03-2012, 06:27 AM
ToxicWS6's Avatar
Look up an ALL flow cat, from frozen boost, what i run and cheap, looks legit and decent quality metal if u weld it
Quick Reply: MSD 2Step VS Catalytic converter?
