Urgent ls1 issues got race this weekend
Old 09-17-2012, 05:19 PM
hempstar420's Avatar
Default Urgent ls1 issues got race this weekend
Rebuilt ls1 from 04 Pontiac gto. Rebuild info unknown which has to do with this problem. Ecu is an ls3 ecu... These can be used to run an ls1? Second can the ls3 ecu use the signal from a 24x crank reluctor? Or only the 58x? Can an ls1 be rebuilt with a 58x crank reluctor an 4x cam reluctor while still having the cam sensor on the back of the engine? Need this fixed tonight going to pull off valve cover after work to check what cam reluctor
Old 09-17-2012, 05:49 PM
wildcamaro's Avatar
Ls3 is designed for 58x...yes you can change relict
Old 09-17-2012, 05:50 PM
wildcamaro's Avatar
Ls3 is designed for 58x...yes you can change reluctor wheel on crank...no you can't have 4x cam sensor unless you move to front cover
Quick Reply: Urgent ls1 issues got race this weekend
