TH400 no speedo?
Old 09-17-2012, 06:34 PM
95killerz's Avatar
Default TH400 no speedo?
I got my turbo 400 a few months back finally got around to hooking up the speedo wires and Im not getting anthing its got a 90s pickup truck electric speedo setup. I got the pigtail from gm I've wired it both ways. Is their a way to test the sensor?
Old 09-18-2012, 09:49 AM
Gingervitis Addict
slow67's Avatar
Hook up a multimeter. Put it on A/C volts. It should pulse A/C volts (somewhere around .5V and go up from there).
Old 09-18-2012, 11:16 AM
95killerz's Avatar
Is one side + and the other - or ground the meter to chassis
Old 09-18-2012, 04:00 PM
Gingervitis Addict
slow67's Avatar
The ground in theory can go to the chassis, but in the stock wiring harness, they both go to the PCM, so I would put the meter on both leads.
Old 09-19-2012, 07:29 PM
95killerz's Avatar
I will give that a shot over the weekend, hope its just a pinched wire or something not the sensor
Old 09-19-2012, 07:36 PM
StraightTimeStirrups's Avatar
What colors are the wires you are hooking up to that go to the Speedo?
Old 09-19-2012, 07:54 PM
95killerz's Avatar
I'll have to check the colors tomorrow my car is down at my work
Quick Reply: TH400 no speedo?
