best oil pump out there?
Old 09-19-2012, 07:10 PM
SStressin's Avatar
Default best oil pump out there?
so i have a 383 that has been going thru oil pressure problems since day one.. so im pulling motor bringing it to cartek and there going to diagnose it check bearings etc.. while its there going to bring a brand new oil pump. whats the best out there and the one that will give the highest pressure etc?
Old 09-19-2012, 07:39 PM
crainholio's Avatar
Can't go wrong with Katech or TSP blueprinted pumps. Pressure yield is all about bearing clearances and oil pump relief plunger spring pressure.
Old 09-19-2012, 07:46 PM
thepitstop2010's Avatar
These are the only two that I use in my builds. I have used both and have had no issues with either. I use the Katech more often due to using their C5R chain so I order at the same time. Can't go wrong with either one.
Quick Reply: best oil pump out there?
