What is a better rod design
Old 04-08-2004, 12:15 AM
goober35's Avatar
Default What is a better rod design
Would you rather have I or H beams rods and Y.
Old 04-08-2004, 05:01 AM
RunNE1's Avatar
If I remember correctly, H Beams are better for compressive loads(forced induction). I beams are better for tensile loads (high rpm N/A motors) .
Old 04-08-2004, 06:36 AM
SublimeRT's Avatar
I'd rather have H-Beams. I read a big comparo on the two a while back, but all I can remember is I'd rather have the H. I'd imagine an H is a lot stronger since the whole width of the rod is as thick as the rod, unlike an I. It just seems like it'd be a lot less vulnerable to twisting and bending in any direction.
Old 04-08-2004, 07:35 AM
Cstraub's Avatar
H beams are fine for lower rpm, to around 6K After that the "load" changes on the rod and I beams are stronger.
Chris
