944 LS1 Road Race Dyno Results
Hi, I just finally got the car dialed in and had it dyno tuned today with the new motor. I figured I would post the results to share with the community. I am going to Watkins Glen in October to run the car. Set up is as follows...
- stock LS1 intake, 228R cam, PRC 5.3L stage 2 heads, hardened pushrods, LS2 timing chain, ported and high pressure Texas speed oil pump, LS7 lifters, forged J & E Pistons, full open exhaust with X-pipe.
This is a full road race car. The car put down 414 RWHP and 393 ft. lbs of torque. At 2000 RPM over 300 ft. lbs was ava. and at 5400 RPM it was making over 400 RWHP. Very happy with the numbers and the build.
Here is the link from you tube on the 2nd pull when we got it dialed in...
The components from Texas Speed were great and made super power for the set up I wanted. I live in NE PA, so Phoenix Performance built the motor, in specific Larry Roberts. He did an awesome job and Mike from Rapid Motorsports did the tuning at Phoenix performance. These people were both recommended to me from the LS1 Tech community. Great advise that I thank now. Just wanted to give some feedback and thanks to the LS1 tech community and share some results to other enthusiasts. Thanks again.
Sam Segond
Sam Segond
