Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
3.4L to Lq9 swap which ecu/pcm
Old 09-24-2012, 07:44 AM
Bunk's Avatar
Default 3.4L to Lq9 swap which ecu/pcm
Which harness would I need, the one that goes with the Lq9 motor correct?
Old 09-24-2012, 01:47 PM
OutlawDrifter's Avatar
you can make anything work, just depends on how much time/effort you want to spend.
as far as the ecu, you need to decide if you are going drive-by-wire or drive-by-cable for your throttle body. if you can get a harness from a 99-02 camaro, that would be ideal for drive-by-cable
Old 10-01-2012, 08:03 AM
Bunk's Avatar
ok thanks!
Quick Reply: 3.4L to Lq9 swap which ecu/pcm
