How Noisey/Loud are extrenal pumps?
Old 09-25-2012, 11:06 AM
Mrpiercings's Avatar
Default How Noisey/Loud are extrenal pumps?
Im a newbie and have decided to start stock piling parts for my projects. 75 Pontiac Grandville and a 75 Caprice, both are 5000lbs convertible so they will never see the track just cruising cars. I keep reading about folks saying that external fuel pumps are loud. Any help would be great, Im searching for two plastic impala tanks after reading write ups about using them instead of pricey after market tanks.....
Rodney
Old 09-25-2012, 11:30 AM
99VetteFRC's Avatar
I have a A1000 mounted to my trunk pan and it is noisy but not as much as the Holley black pump that pwered the BBC. I don't mind the noise though. Not unbearable.
Old 09-25-2012, 02:54 PM
Pop N Wood's Avatar
Depends on a lot of different things, like how it is mounted, the type of mount isolators, how much sound deadening the car has, the size of the pump (bigger = louder) as well as the type of pump (gerotor vs. rotary vane).
I will also add the noise depends on how low you can mount it (lower = quieter), the size and type of fuel lines and how they are isolated, and believe it or not the type of prepump filter you have. The noise on mine went down a good bit when I went to a lower pressure drop prefilter.
Old 09-25-2012, 07:36 PM
69importkilla's Avatar
Just installed a Holley HP150. Really quiet, like not even sure its running...LOL
Old 09-25-2012, 08:37 PM
spot_55's Avatar
Have a walboro 255 in my chevelle,same in my brothers 65 pickup,and the same in a friends 84 pickup all are in line and all are quite. all ls converted as well ,2 with vette fpr set ups and the other with the return from the rail.
Old 09-25-2012, 09:01 PM
79LS1FOX's Avatar
Default pump noise
I have a walbro 255 mounted at the back of my car and I dont think it's all that noisy, AN-8 feed to corvette filter/regulator AN-8 to fuel rails. I did buy the insulated mounting kit with the pump which I think helps some.
Old 09-26-2012, 04:17 PM
Doug G's Avatar
LS1Tech 10 Year
Aeromotive SS...can sorta hear it IN the car....sorta
Old 09-26-2012, 04:40 PM
rockytopper's Avatar
Only time I hear my walbro 255 is when I hit the key at initial startup and I'm glad I do it lets me know it's working. I here it kick on for 2 seconds then off. I then bump the key and see fires every time.
Old 09-26-2012, 11:19 PM
kballs's Avatar
Default pumps
I run a bosch 044 pump. Awesome quality, quiet, reliable as they get. Beware of knockoffs.
Old 09-27-2012, 10:49 AM
78_elky's Avatar
I replaced the stock pump in my Camaro with a Delphi unit and it is louder I think than the Holley Red I have mounted to the rear frame on my El Camino.
Jessica
Old 09-27-2012, 11:40 AM
Thanks again if I cant find a plastic tank I will try the external pump...Doug G that car sounds Great but my wife and all the houses around me would hate me....lol
Old 09-27-2012, 03:51 PM
Doug G's Avatar
LS1Tech 10 Year
2 Harleys,and a 70something Vette w/ side pipes are neighbors....they have no problem .......now the old people up the street.....another story
edit: and I can't forget Sixtoes (member here lives around the corner donw the street) reving or pulling holeshots as he goes by from time to time....lol
Quick Reply: How Noisey/Loud are extrenal pumps?
