Check engine
Check engine
Cars throwing a few codes... It throws a o2 high voltage bank 2 sensor 2. o2 low voltage bank 2 sensor 1. and cylinder 6 missfire detected. I know before my EGR seal inside the intake was screwed up but i placed it correctly. Could that possibiliy be throwing the o2 codes? also what could cause the cylinder 6 misfire? this is very annoying to me. and dont know were to start....
LS1Tech Premium Sponsor
For the misfire problems I would start by checking wires, plugs, then coils for starters.
As far as the O2 sensor codes, it could be a number of things. Do you have headers or have you changed the exhaust at all? I would start there by cleaning the MAF, then replacing the O2 sensors if that doesnt do anything.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
