LQ9 timing chain issue
Old 09-26-2012, 10:53 AM
Phantom383's Avatar
Default LQ9 timing chain issue
Building a 408 & I bought a timing set from a local hot rod shop, single roller.
Put it on last night and I have at least 1/2" of slop in it.
Do I have the wrong set or am I missing something here????
Thanks
Old 09-26-2012, 01:30 PM
litle88's Avatar
What brand do you have?
Old 09-26-2012, 04:47 PM
Phantom383's Avatar
I thought he sold me a factory GM replacement but now I'm not sure??
Someone told me I needed a LS2 Timing Chain Tensioner but after looking at them on line and looking at my block........well there are no holes to attach the darn thing too
Old 09-26-2012, 05:30 PM
litle88's Avatar
Yea I'm sure they weren't on the Lq's but iirc they can be tapped for it. I have a C5r timing chain and they are a little tighter than an Ls2 chain.
Old 09-26-2012, 05:56 PM
Phantom383's Avatar
Looks like my choice's are:
A: Drill a fully assembled Short Block and buy a 15.00 part
B: Buy a Cloyts Hex Adjust for 175.00
Not thrilled about either!
Thanks for the reply's 88
Old 09-26-2012, 09:02 PM
CAMSTER's Avatar
Take the chain back and get what you need.
Old 09-26-2012, 09:26 PM
06X6spdGTO's Avatar
Running a LS2 Chain on my LQ9... No Tensioner. Shifting it a 7300rpm with ARP rod bolts...
Old 09-27-2012, 12:58 AM
pairof69s's Avatar
I plan on using this on my LQ9 with a LS2 chain n dampener
http://www.summitracing.com/search/?...30675600&dds=1
Old 09-27-2012, 02:09 AM
bww3588's Avatar
Agreed. The trick flow dampner will allow you to use the Ls2 dampner without drilling holes.
Old 09-27-2012, 04:43 PM
Phantom383's Avatar
So will that bracket with the Tensioner take care of the slop or is it just to help keep the chain straight?
Old 09-27-2012, 04:51 PM
Phantom383's Avatar
Here is my other option:
Called Cloyes and this is what they said I needed and said I would have .062 slop
http://www.summitracing.com/parts/CLO-9-3158A/
Old 09-27-2012, 06:58 PM
litle88's Avatar
Damn those dampners are new to me! Good to know.
BWW3588!!!
Your slow!!!
Old 09-28-2012, 10:52 AM
06X6spdGTO's Avatar
didnt know about that dampner either!!! GREAT POST!!!
Quick Reply: LQ9 timing chain issue
