4L60E Bouncing off limiter before shifting into 3rd at WOT??
performabuilt lvl 3 4l65e, car is a 00' trans am with d1-sc making 644rwhp 648rwtq transmission was performing flawless at 590 whp shifting great, now after i got pullied down and retuned it started hitting the rev limiter for 2 seconds before finally shifting into 3rd, drives around at part throttle great its only at wide open throttle that it does this, cant figure out why and the tuner said its not in the tune....
Well, this happened to me and sure enough my the gear band took a ****. It will eventually get worse my friend. The trans finally ended up not being able shift out of gear. I'm no guru, but can speak from experience. I just had it rebuilt for a second time. 3-4 clutch went out this time.
