FAST 60-lb/hr fuel injector set, 306000 (8), high impedance, Minitimer connector
Category: Engine - Intake/Fuel
Price: $275
Location (State): NC
Item Condition: Used
LS Engine?: Fits LS Engine
FAST™ Fuel Injectors
PRECISION-FLOW™ FUEL INJECTORS
State-of-the-art magnetics improve injector opening times in order to yield faster throttle response
Precision ground pintle and wide spray angle both help to produce and deliver superior fuel atomization
Redesigned valve body resists clogging & improves hot starting
High-impedance injector models available up to 60 lb/hr for trouble-free OEM computer or XFI™ compatibility
FAST™ Precision-Flow™ Fuel Injectors deliver the outstanding idle quality, unparalleled flow consistency and durability essential for high performance EFI engine applications. Engineered to yield faster throttle response, reduced clogging and superior fuel atomization, Precision-Flow™ Fuel Injectors are manufactured to the tightest tolerances in the industry.
60 Lb/Hr High Impedance Long Injector
Supports up to 864 normally aspirated horsepower when used in an 8 cylinder application. High impedance for use with OEM computer.
