First runs with cam and n20. Not so good....
Old 09-29-2012, 03:36 PM
sweet99ss's Avatar
Default First runs with cam and n20. Not so good....
Well I really wanted to trap atleast 113 on motor, but I think I need just a little better D/A. First time spraying n20 at the track and only sprayed it twice. I was having trouble with it hitting rev limiter and having trouble with it spinning when it came in so my window switch was set at 3700rpm-6000rpm. Next month I want to go back with m/t dr's and set the window switch from about 3300rpm-6100rpm. Also need to get back down to the 1.7 60ft range instead of high 1.9's .
[url]http://www.youtube.com/watch?v=IfmKKCGQrZc&list=UUi1dudkL1GxpNGxTvg1ZO8A& index=1&feature=plcp[/u
Old 09-29-2012, 03:55 PM
chadroosa's Avatar
pretty good.. what tires r u using
Old 09-29-2012, 06:17 PM
Captain Double Post
BOBS99SS's Avatar
Not to bad if you were having issues, we are having killer air, this is the best time of year to be running, i couldnt see the vid but get your lil issues worked out,throw on a drag set up and you should do much better on your times
Old 09-29-2012, 09:37 PM
sweet99ss's Avatar
That is pretty decent d/a for here. If I could get the same d/a like i had when I ran 12.3@109.5 with bolt-on I would be running about 114.. With the same 60ft and d/a I would run like 11.8@114. N20 I think I mostly need tires for more gains with that because when it would come on in first gear it would spin. I was pretty happy to trap 120 though. I think with some adjustments with the window switch I can gain more mph with the n20 also.
Quick Reply: First runs with cam and n20. Not so good....
