H/C/I project setup
H/C/I project setup
i have a 01 T/A
Im going to a H/C/I car
Intake Mainfold
Fast 102mmLSXR Intake Mainfold
Fast LSXR Fuel Rail Kit
Nick Williams 102mm TB
LS6 Patriot Stage 3 Heads
APR Head Bolt Kit
LS6 Oil Pump
GM MLS Head Gaskets
Water Pump Gasket
APR Lube
Walbro 255LPh Fuel Pump
SLP Polished Dual Tips
LSX Tuner from Fastporms at Tampa
Prothane Motor Mounts
im planning to do this setup soon, wanted to make sure i got the correct items and gaskets.
thanks
Intake Mainfold
APR Head Bolt Kit
LS6 Oil Pump
GM MLS Head Gaskets
Water Pump Gasket
APR Lube
thanks
The Scammer Hammer
i have a 01 T/A
Intake Mainfold
ARP Head Bolt Kit
LS6 Oil Pump
GM MLS Head Gaskets
Water Pump Gasket
ARP Lube
thanks
Intake Mainfold
ARP Head Bolt Kit
LS6 Oil Pump
GM MLS Head Gaskets
Water Pump Gasket
ARP Lube
thanks
The SLP tips are going to look tiny. Get a set of corsa clones. Check out eworldsales1 on ebay.
Don't forget the hotwire kit with the pump.... Racetronix is great.
If you're doing motor mounts, at least get a new rubber trans mount. Or poly... you're choice.
Don't forget the trunion upgrade if using stock rockers, as well as new PR's
I'd personally rethink the Patriot stage 3's. At least get some PRC's from Texas Speed. They have killer prices for ported stock heads or even aftermarket. Their 2.5's make good power, whether ls6 heads or 5.3's.
http://www.ws6project.com/user_stor/...-ported-heads/
i saw this pump and hotwire i think
http://texas-speed.com/p-2358-racetr...ic-system.aspx
and this was my second choice in tips.
http://shop.advanceautoparts.com/web...983%7CL3*15328
thanks
Don't forget lifters. Ls7 should do.
Might need new cam retainer plate since that gasket is built into the plate.
My timing chain cover gasket came with water pump gaskets.
Front and Rear main seal
