2002 SOM z28
Old 10-05-2012, 10:39 AM
wickedlsx's Avatar
Default 2002 SOM z28
first off its still a project. I bought it as roller put my motor and trans out of 98 z28. Body has 54k motor was "rebuilt from previous owner" i took motor apart heads and oil pan off put all new gaskets on everything for motor and there was still cross hatches on cylinder wall so i do believe motor was rebuilt. Trans was just rebuilt after front pump got broke during re-install and it was built before with all the goodies vette servos beast sunshell etc.
Good
54k on body
All new gaskets on motor ALL of them are NEW.
Rebuilt trans with no miles
Fresh mobil one oil
Brand new ngk tr55 plugs no miles on them
Brand new MSD superconductor wires no miles
Brand new racetronix fuel pump and wiring harness(harness needs installed) no miles
slp lid with brand new K&N filter
hooker supercomp lt's
umi panhard bar and rear lcas
edelbrock torque arm
welded in subframe connectors
koni single adjustable front struts
lowering spring
4.11's with royal purple fluid in diff
ss hood and spoiler
its SOM
Paint is near perfect one little dent
other stuff im forgetting I'm sure
Bad
-Interior is stripped but have all panels and have carpet but has holes from cage
-window cowl has been cut out (to clear victor junior)
-hvac delete (can be good also I guess)
-Cranks and backfires but does not start Have 98 pcm and engine harness on car now but I bought 99-02 pcm and waiting on wiring harness.
I'm trying to get it running but if i cant I will sell as-is thats why I'm posting in here to see what it would be worth as it is right now.
Old 10-06-2012, 06:27 AM
camaroboy14's Avatar
Tough.. I will say 5-6.3k
Quick Reply: 2002 SOM z28
