Coupler/Bellows for WS6 intake?
Old 10-09-2012, 09:11 AM
MasterTomos's Avatar
Default Coupler/Bellows for WS6 intake?
I bought a used WS6 ram air intake for my '95, but it doesn't have the bellows to attach to the MAF or throttle body. SLP sells new bellows for $65 bucks, which seems pretty stiff.
Did some research, but all I could find was stuff for LS cars, which of course have a circular throttle body. Has anybody run into this with an LT car?
Old 10-09-2012, 09:30 AM
93M6Formula's Avatar
Honestly you can go to the hardware store, Menards, Lowes, whatever and grab a couple pipe couplings and use that. I believe you need a 4.5" coupler for the TB with a reducer to 3.5"? I'm pretty sure that's what mine is and I also used 3.5" O.D. PVC pipe for a spacer.
Old 10-09-2012, 10:04 AM
RamAir95TA's Avatar
You need a standard 3" pipe size Fernco sewer pipe coupler with two band clamps - that's it.
Put the coupler in boiling water to soften it up and it will slip easily over the throttle body.
Old 10-09-2012, 10:34 PM
1961ba427's Avatar
What about between the MAF and the airbox? On the Suncoast air box I have, there is a rubber insert in the end of the airbox opening to seal to the MAF. The OEM airbox I have doesn't have one anymore. The Fernco looks to thick to use in that location, but I could be wrong.
Old 10-09-2012, 11:50 PM
I have read about fernco couplers and thats kind of what I was leaning towards for the TB/MAF connector. Are those "cut to length" at the store, or do they come in different sizes? If so, what length would be needed?
EDIT: Just found on another thread the part number for the fernco piece. Fernco coupler #1056-33. (It's 3" in length, 3" in diameter) Just thought I'd throw that number in here for anybody searching in the future. They're $7.99 on ebay. Do you recall if that's what you're running on your intake joe?
Also wondering about the MAF to airbox connection still.
Old 10-10-2012, 12:29 AM
speed_demon24's Avatar
You could get a coupler designed for it instead of a piece made for sewer pipe.
http://intakehoses.com/Merchant2/mer...gory_Code=RHH8
Old 10-10-2012, 04:53 AM
RamAir95TA's Avatar
What's with the chubby waist? Looks like your throttle body has a muffin top. For $18+ shipping I'll pass.
$5 at the hardware store. Nyea.
Old 10-10-2012, 06:00 AM
Rob
Rob's Avatar
Fernco all the way, been on my car for at least 14 years with no problems.
Watch what you say about the Fernco on LS1LT1.com though, you'll get banned. Ask me how I know...
Old 10-10-2012, 06:16 AM
1961ba427's Avatar
No answer on the MAF to airbox connection?
Old 10-10-2012, 08:54 AM
I have the Suncoast box also, my situation might be different since I have a '93 with no MAF, but I used some PVC pipe and put that rubber gasket around the pipe and inserted it into the air box, then just used a worm clamp on the box.
I probably didn't explain it too well but I will post pics of mine tonight or tomorrow morning if that helps.
Here's the order of my setup though. throttle body, coupler, PVC pipe, gasket, airbox. Has worked good for me for 4 years.
Old 10-10-2012, 08:56 AM
1961ba427's Avatar
I've got the gasket with my Suncoast box. I also have a GM WS6 box for another car and no gasket for it.
Old 10-10-2012, 09:04 AM
Oh I see what you're saying, If you happen to have a stock non-ws6 intake box, that same gasket is on there also I believe? I think I had to use that on mine also but I can't remember.
Old 10-25-2012, 02:45 AM
Alright, here's an update. I picked up the 3" fernco connector. I got it on to the throttle body without having to heat it up at all. MAF fits into it fine. However, it goes "straight" into the radiator. I was able to bend it up a little to slip the MAF above the radiator, but with the factory radiator cover, it's out of the question. I'm running a suncoast airbox, so maybe that has something to do with how it's all fitting together.
The OEM and SLP ones "bend up" as seen here: http://www.hawksthirdgenparts.com/ca...nts/Air-Boxes/
Looks like I might be spending $60 on a 4" long piece of silicone
Also, is anyone running MAF extensions? I can get my connector to clip in but the wires are kind of tight for my liking.
Old 10-25-2012, 03:35 AM
I would rather have something engineered to flex when the engine torques over something out of home depot.
Old 10-25-2012, 04:06 AM
RamAir95TA's Avatar
If your engine flexes THAT much where it's going to pull out of the MAF or throttle body you *might* want to get some new motor mounts or something. I've had mine on there for TWELVE YEARS and never once has it popped off.
Either that or you've got WAY too many horsepowers.
Let's continue to split hairs, shall we?
Old 10-25-2012, 04:18 AM
Lol, maybe my last post was worded a little poorly. Im not worried about the silicone coupler/"bellows" coming off, I am worried about how tight the MAF wires are pulled where it plugs into the harness (they're at their absolute limit). I also have to run my MAF a little cockeyed in order to even plug it in and don't like the looks of it (that's just cosmetic, however).
*EDIT* After re-reading, I assume you were responding to speed demon lol.
Old 10-25-2012, 08:20 PM
warriorcustoms's Avatar
Dude Delete your mail box I sent you detailed instructions Only to get kicked back saying you dont keep up with the mail LoL The 3in coupler & stock maf rubber is all you need its not that much of a bend All the rest of us are pimpin the $5 dollar or free from work pc of plumbing Mines a lil different because I have the NX Maf ends Still works
Old 10-25-2012, 08:23 PM
Not installed since Im buildin a 396 right now but you get the picture LoL
Quick Reply: Coupler/Bellows for WS6 intake?
