Head Gaskets??? Can a LS1 block handle 1000rwhp???
I am posting this for a friend. He is running a single 96mm (not sure what kind), forged ls1, stock crank, and 317 heads. He wants to know what head gaskets he should go with. He is planning to run around 23-25lbs of boost and is shooting for around 1000rwhp. Could he use a stock GM head gasket? what would you guys recommend? And can the stock LS1 block and crank handle a 1000rwhp?
use to be that you would pick up the 6.0 MLS gaskets, but now that the ls9 ones are readily available you can't go wrong with them. I think they are a 7 layer gasket.
I didnt know that. I thought the bore size would be way too big for a LS1 or 5.3. Looks like he will be going with ls9 gaskets then. Can they handle 23-25lbs? What can the stock LS1 block handle?
Not many ls1 blocks been above 1k that I know of. I have seen a few but just a handful. 1k should be ok if everything has been prepped right and maybe extra precautions taken like pinning mains etc.
Stock crank i have seen many run well above 1k. Should be just fine there
Lifting the heads are all different for people. Some lift and push water at 12lbs and some never even running 25lbs. honestly there are several factors that play in this.... head deck thickness, surface prep, head gasket type and prep, cylinder pressure, and mostly TUNE. We have no way of telling how your friends tune will look but if all precautions are taken then he should be fine. 317's have been to 1k no problem and even so very few have pushed water. Since he is using 317 heads then deck thickness wont change, make sure the surface and trueness across the head is good, and use ls9 gaskets well prepped with copper spray and watch where you touch on the binding surfaces. Also use PLENTY of clamping force...to be had through ARP. At that boost level ARP studs ftw.
Good luck
