How do I edit CAT Test count to pass value?
Old 04-09-2004, 07:00 PM
kodiakz's Avatar
Default How do I edit CAT Test count to pass value?
Help!! I received a tune from Magnusun and copied all the tables over into mine (same year and motor) and everything runs great (supercharged 5.3L) EXCEPT now I keep throwing the darn P0420 and 0430 codes which rarely happened before. When I try to append the values in either the CAT Test field or DTCP0106 field, the values do change abd I then save the file. However, when I reopen the file all the values have shifted back to their previous numbers. Am I doing something wrong here and will changing those particular #'s affect the P0420 dtc? Thanks!!
Old 04-09-2004, 08:37 PM
felton316's Avatar
Maybe Magnusun has locked their tune?
Old 04-09-2004, 09:25 PM
kodiakz's Avatar
Actually, John sent me a file from another truck like mine so that I could copy everyting over into my file. Everything else copied just fine and the truck really runs now--except for the damn cat codes!!
Old 04-10-2004, 07:16 PM
felton316's Avatar
Are you hitting the 'apply changes' button before saving and closing the program?
Old 04-11-2004, 07:04 PM
kodiakz's Avatar
Actually, under that particular tab there is no apply changes button. So I have tried saving the file both before and after I close the window with the edit made and still no joy Thanks for the replies though!
