1LE 1994 How much is it worth?
Throwing codes 42 and 36.
1994 1LE Camero
1 0f 134
Lt1, 6 speed manual, and
INTAKE-
SLP cold air intake kit
52 mm throttle body
2pc pully kit
COMPUTER-
Costom Mapping on CPU-to match all performance mods- speedo recalibrated
Low temp thermostat 180
Skip ship-bye pass
EXHAUST-
JBA headers-into 3in Y pipe-locking APR hearder bolts
High Flow Cat
Borla Cat back system
TRANSMISSION-
Center Force Stage 1 Comp. Clutch/Clutch Disc/ pressure plate
Heyes lightened Alloy Flywheel-APR bolts
Billet Specialist-Aluminum Drive Shaft
G.M. ring and pinion Gear 3.73-speedo recalibrated
T/A girdle kit
MTI- Short shifter
SUSPENSION- ALL HOTCHKIS BRAND
Hotchkis Front Strut tower brace
Hotchkis Lower trailing arms
Hotchkis Pan Hard Rod
Hotchkis Sub Frame connectors
BRAKES-
Stainless steel brake lines
High performance brake pads
1994 1LE Camero
1 0f 134
INTAKE-
52 mm throttle body
2pc pully kit
COMPUTER-
Skip ship-bye pass
EXHAUST-
High Flow Cat
TRANSMISSION-
T/A girdle kit
MTI- Short shifter
BRAKES-
I only got $4200 for my bone stock 94 1LE with 71k miles. It needed paint on the hood, front fenders and roof but was sound other than that. Had a brand new GM opti, waterpump, 255 pump and brakes all around when sold also.
Bought a stone stock 95 Z28 convert with 21,100 original documented miles in near mint/showroom condition for $7600 in central Washington state. Already turned down $11,000 here in Sarasota Fl. Condition and location really affects demand , which affects price.
