MWC 9 rear, axle seal leak?
The passenger side axle seal on my MWC rear is leaking, the rear is equiped with Moser axles. The bearing and seal have been looked at and replaced by two different shops, and it continues to leak. The rear is not over-filled and the vent tube is clear. The four retaining plate bolts are plenty tight also.
Has anyone else encountered this problem and did you find a solution?
Thanks for any help.
Its the older style Moser bearing, its not the one that is one piece with the seal incorporated into the bearing. I can get you a better answer in a few, when I contact RPM and check with them, they are the ones who replaced the bearing&seal. It leaks right under the backing plate, near where the emergency brake is located. Thanks Eric for answering up, the leak is small, but it`s a pain in the *** because it messes up the wheel and contaminates the brake pads.
Mike G
Mike G
LS1Tech Premium Sponsor
Any help here? Gonna have to clean it off and drive it for a few miles and look into it closer than "off the bottom of the backing plate"
No real reason for one side to have issues with new bearings. Axle have excessive runout? Axle nicked where seal lip rides?
When I installed my Moser 9", I installed one seal and then applied sealant around the edge of it, and THEN read instructions that says to put sealant around the base, install the seal, and put more sealant around the outside. Well guess which one leaked?.. I ended up pulling that seal and applying sealant on both sides, and all has been fine since.
