5.3 turbo build in a 71 Firebird
Hello all,
I am in the process of swapping in a LM7 into my 71 Firebird.
I am wanting to put a turbo on it as well.
My question is do I leave the stock cam and valve springs in or I have seen people use the LS6 ones?
Also the motor I got was basically free and did not include a harness/PCM. I plan on using a 4L60E for the transmission.
Do I need a certain year PCM, Harness and trans module?
Also if you guys have any more suggestions that would be great! I have read many awesome builds on here already.
Thanks,
Aaron
Thanks,
Aaron
Hey Aaron,
Many people will change the cam (and springs) while the engine is out. The LS6 cam specs are:
Year Duration Lift LSA
2001 - 204/211 .525/.525 116 lsa
2002-2004 - 204/218 .555/.551 117.5 lsa
Its a good "cheap" upgrade. BUT, consider spending a little more and getting a bigger turbo cam or a custom grind. If you go with the LS6 cam, try to get one that's from a 2002-2004, if possible. More lift, more exhaust duration, and wider lobe separation.
I'm in the same boat as you. I've got a 72 Camaro that's getting an LM7. Still working out the details (motor mounts, etc). Will eventually be getting a front mount turbo. Hard part is, I'm keeping AC, so I have a little extra work figuring out how to mount everything.
