shifter retaining pin
Old 10-30-2012, 07:48 PM
Ron_Stoppable's Avatar
Default shifter retaining pin
Can someone please tell me where i can get the small nailish looking pin that goes above the shifter shaft. Mine broke. My trans is a 95 4l80e Van transmission. There was like this stupid metal plate blocking it so i bent it a little to wedge it out. Just for future reference, is it requirrd to remove the ENTIRE pin or just pull up on it ?
Old 03-04-2015, 11:58 PM
steve2248722's Avatar
not sure where to get the pin but maybe you can help me how the heck do you get that pin out
Old 03-05-2015, 10:29 AM
JRENIGAR's Avatar
Removal of that pin is required to remove the shift shaft. Mine broke and I had to drill several small holes around it not very deep but larger in size. I rounded off a set of needle nose vice grips to grab what was left of the pin. I used a small propane torch to heat up the aluminum base around it and it came right out. I had to get my converter supplier to send me another one as GM dosent sell them. The valve body needs to be removed to properly get the pin out.
Old 04-20-2016, 08:44 PM
xmbreezy's Avatar
I just had the same issue and I broke the pin clean and off and there's nothing to grab it with. Anyone have any suggestions?
Quick Reply: shifter retaining pin
