Ideas on how to salvage my TFS 225s?
Old 10-30-2012, 08:12 PM
WADDISME's Avatar
Default Ideas on how to salvage my TFS 225s?
[IMG][/IMG]
Broke a valve spring but didn't know it and did a full track day with it broken. Spring chewed up locator and shim and galled out this ring in bottom of head. Can I shim up grooved spot to original height? Or should I have it milled out even and then shimmed to correct height? I can't imagine being able to fill in grooved area with anything, but that would be the easiest.
Thoughts?
Old 10-30-2012, 09:48 PM
Tainted's Avatar
Id have that milled flat and true and shim it
Old 10-30-2012, 10:21 PM
HPbyGD's Avatar
X2
Gary
Old 11-01-2012, 04:12 PM
-TheBandit-'s Avatar
With a broken valvespring, I think I'd be more worried about valve-piston interactions. Have you done any kind of leakdown on the cylinder to see if the valve is holding air? It may be bent or worse.
Old 11-02-2012, 07:22 AM
WADDISME's Avatar
There was zero noise from valve train and cylinder still holds air without leaking. I was going to just change springs and do compression check and if OK, then not pull heads. I did check the push tubes and they were still true. No matter now, as I am pulling the heads. TFS recommended having them milled for a cup. Not sure what that is, but racing shop that is doing it does. Anyway, I will get a look at piston and valves tomorrow. When all that is done, I still have to drop cradle, pull oil pan, and find the missing pieces of the locator and shim. I hope they are in the top part of oil pan and in the oil filter.
Quick Reply: Ideas on how to salvage my TFS 225s?
