Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Weldon 1100-A Fuel Pump
Old 10-30-2012, 10:47 PM
2JZFC's Avatar
Default Weldon 1100-A Fuel Pump
Category: Engine - Intake/Fuel
Price: $300
Location (State): FL
Item Condition: Used
LS Engine?: Fits LS Engine
Selling this for a friend.
Weldon 1100-A
Bought this pump used, ran it for a few months, and sent it off to
Weldon. Weldon cleaned the "brushes" in the pump. Apparently they had
become varnished from sitting for a long time (due to bad gas before I
received it). It was cleaned, flowed, and returned to me in
essentially new condition, ready to run. When I sent this one to
Weldon, I bought a new 1100-A to get the car running while they had
mine. I received this one back and with a clean bill of health, so it
is for sale...
Here are some specs from Weldon Racing's website...
Maximum HP:
1100 hp Inj/1300 hp Carb
GPH/PSI Range:
135 GPH/0-95 PSI
Features
Extremely quiet
Smooth, precise fuel delivery
Extremely low current draw
Self Priming
Pump may be mounted above fuel cell
vertical or horizontal mount
All internal wear components are 100% metallic
No plastics or composite materials are used in the 1100-A pump. This
results in the longest lasting, highest quality most durable flow
through pump available.
The housing is made from corrosion resistant 304 brushed stainless steel
Mil-Spec Clear anodized billet end caps with No-Leak seals and
stainless steel electrical connectors
-10 inlet and outlet with leak free o-ring ports
6.25 lbs
Two stainless steel T-bolt style clamps included with each pump
Long life, continuous duty
•Compatible with Gasoline Only (not compatible with alcohol / ethanol
based fuels)
Requires appropriate bypass regulator, a -8 return line is recommended.
•This is essentially a new pump after being cleaned, flowed, and
inspected by Weldon.
•Includes everything pictured (mounting brackets, instructions and decals)
Quick Reply: Weldon 1100-A Fuel Pump
