Clutch setup in fox body with ls1 t56.
Old 10-31-2012, 02:15 PM
LSX FOX's Avatar
Default Clutch setup in fox body with ls1 t56.
I haven't seen anyone do a setup like mine yet so i thought id share since it was very simple to do.
i took the wiring harness out that going to the starter solenoid etc..and i pulled it through the fire wall under my dash and then ran it out of some grommet that goes straight into the left fender area(inside the fender) and then reconnected everything. I made a bracket setup for the clutch master cylinder to stick straight out of my firewall and shortened the rod about an inch. then i made an easy bracket setup for my clutch pedal and used a brake caliper bolt and rod that comes off the bracket to the rod of the master cylinder and then bled the system and it works awesomely.
its not the nicest setup i know, but i didn't really spend a whole lot of time on it either, but here's to help anyone that is trying to think of an idea on a clutch setup.
Attached Thumbnails Clutch setup in fox body with ls1 t56.-picture-156.jpg   Clutch setup in fox body with ls1 t56.-picture-157.jpg
The following users liked this post:
Spankyyyy (02-07-2023)
Quick Reply: Clutch setup in fox body with ls1 t56.
