I love my car, but.....
....its driving me insane! Not really, I just want it to be done already. Ok here's the problem, burned a plug wire, but with the pace setter headers it was easy to replace. Ran everything correctly AND whlie I was in there I changed out my stock elbow, for a trickflow aluminum elbow to my 58mm tb. Its got a cold air kit on it already, but now it backfires and shakes something fierce. Found a broken O2 sensor wire, and am in the process of replacing the O2 sensor, my question is if this doesn't work, could I have fouled the plug or do I need to re-tune the whole setup together??? Any help is greatly appreciated and after this I'm starting on my suspension.......
LT1, bored .030 over, Comp Cam, Pacesetter Long Tubes w/ ORY- pipe, Cats and EGR deleted, Magnaflow exhaust note. MSD ignition module, 58mm throttle body, cold air intake, Gasket mapped heads, Ported intake. B-cool radiator...
I forgot, 2300 stall, stage 1 shift kit, magna flow exhaust with mandrel bent tubes from headers to the back.
