Fuel line with rail help?
Need lines from the stock lt1 rails under the car to fast rails on a super vic intake setup. Also with the use of a regulator in the engine bay.
How did you do this what line kits were used and regulator?
pix and part numbers will be greatly appreciated.
Need it to be a feed and return style system using stock lines under the carriage. But prefer a -8 lines/fittings
I used Purechoice 30" braided line and just did a double-roll flare on the stock lines. I have a stock fuel rail but if you call them and tell them what you need they can assemble anything you need. Just check out their site http://www.purechoicemotorsports.com/
hope this helps man
