Who can tune 98 pcm
Don't bother swapping the PCM, the only difference is that they don't have as much memory. So unless you are running a speed density tune and want secondary map settings for race gas I just don't see a reason to spend twelve hours re pinning the harness for a new ecu
The good thing about 98's is the dash reads directly from the sensors, where as other years just relay settings from the ecu
