Turbonetics NEW 7675 and 7875 Turbos AVAILABLE through Huron Speed!
Turbonetics is finally releasing their new upgraded Turbine wheel! The Turbine wheel is 75mm, which is a big improvement over their standard 68mm and will allow for much more power, as well as help decrease and eliminate back pressure issues. They are packaging their new wheel in the T-series housings which will compose of a T4 inlet and 3" V-band discharge on the Turbine side and a 4" Inlet and a 2.5" discharge on the Compressor side.
Huron Speed is your #1 source for Turbonetics Turbos!
We have an abundance of the new Turbos already on order, and here are the options available.
Please contact me via PM or e-mail at huronspeedproducts@gmail.com to place and order and or to receive the BEST possible pricing on these or any other Turbonetics components!
All units are standard and only available in BALL BEARING!
#1: Billet 76mm compressor wheel, 75mm turbine wheel, 1.15 a/r housing
#2: Billet 76mm compressor wheel, 75mm turbine wheel, .96 a/r housing
#3: Cast 78mm compressor wheel, 75mm turbine wheel, 1.15 a/r housing
#4: Cast 78mm compressor wheel, 75mm turbine wheel, .96 a/r housing
#5: Cast 76mm compressor wheel, 75mm turbine wheel, 1.15 a/r housing
#6: Cast 76mm compressor wheel, 75mm turbine wheel, .96 a/r housing
Thank you for supporting Huron Speed
Jon
Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
I have already placed an order with them and should have them in the next couple weeks. As they are now available for purchase, I would say yes, they are available!
__________________
Sounds great and one crazy machine! A couple 7268s would easily make over 1000
__________________
They have not released that yet, but the 7868 was rated to 800 hp, so these ones will shine where that would start to tucker out with the larger turbine!
Jon
Jon
__________________
Only offered in Ball Bearing unfortunately. However it will be an awesome unit for a better price than anything comparable!
Jon
__________________
I don't have any pics, but I will see if I can get some before the units I ordered show up.
The 75mm wheel is for the T-series, not the 60 series housing the TC or "Hurricane" turbos are in.
1.15 is a divided housing, .96 is open.
Pricing coming to those that inquired!
Jon
Jon
__________________
