Twin Turbo LS powered AC COBRA Kit Car Build
Old 11-08-2012, 03:37 PM
firefly9r68's Avatar
Default Twin Turbo LS powered AC COBRA Kit Car Build
East Texas Muscle Cars Kit car build: This will take a while as i am building this myself and not really in the shop so this is a 9pm to 12AM project but in 4 months i has got quite a bit done!
Car will be a LS powered car
Sence i was 11 years old and saw the first AC cobra and actually knew what it was i have wanted one. Well i finally had the chance to build me one. I had to sell my 1100+ HP 2010 camaro I built But i got it.
Kit was delivered about 4 months ago:
Super excited about right now!!!! Got the car out then had to unload all the boxes
First things first, found the instructions
i bought a basic kit with all FFR a arms and wilwood brakes, and a moser 8.8.
the car didnt come with the Brakes or the Moser 8.8 so more boxes soon to come!
Old 11-08-2012, 03:42 PM
zapp109's Avatar
I want to do a kit car myself one day in a few years probably but cant wait for you to get some updates
Old 11-08-2012, 03:44 PM
First off the car comes with the body set on the frame and the alum panels just set in place. You have to take the whole car apart, and label all the panels.
Then the fun begins. I started a little out of order but o well. here is the front end and brakes on.
rear end came in about 3 weeks later so in it went!
Old 11-08-2012, 03:45 PM
I will have to apologize now for he crappy pictures :-( they are all from my I phone
now to start on the ALUM. starting with the front:
and moving to the REAR
man that last pictures turned out really bad :-(
anyways at that point i have the gas tank installed already, all the alum is in and sealed. now that was the easy part now to start the brake lines,pedal box,dash, eng, trans......
Old 11-08-2012, 03:51 PM
Brake MC. o what fun, i still dont have them adjusted right may have to rear the instructions for these..LOL..
now it is getting time to move it down to the main shop so i can use the welder and get to going on the motor
so far no real complaints that i have found except the rear brakes i had to have machined to fit the 8.8
Old 11-08-2012, 05:21 PM
MOTOR TIME NOW
for the motor i went with a block i had sitting around the shop. a old ls3 crank. some Eagle rods and wiesco pistons. to top it off some PRC 317 2.5 heads with a ls2 intake.
Went with a fresh t56 and a ACT twin disk clutch
for the mounts i had to cut the ford ones off and make my own mounts. I got some HSC rubber mounts and use the FFR trans mount in the rear with a F body rubber mount. The mounts in the picture are just when i was mocking it up. They are now boxed all in.
THE CUT OFF MOUNT AND WELDED BACK ON
Old 11-08-2012, 05:24 PM
now for the fun stuff. Mocking up the Turbo kit, and putting the March front drive kit on the car
Old 11-08-2012, 05:25 PM
there isnt alot of room in the front of the car so i decided to go with a air to water setup :
if you look down you will see the two innercoolers
Old 11-08-2012, 05:27 PM
NOW TO THE DASH
Old 11-08-2012, 05:42 PM
here are some better pictures i just went and took
Old 11-08-2012, 05:45 PM
now the body is another story. Me and our painter are not to happy with there( 40hrs and ready) body. after taking off the seams they leave you there is alot of voids in the fiberglass under the gel coat which is a big NONO. i am a little worried about the rest of the body and heat and those air bubbles we dont find coming back to haunt us down the road. there is a TON of high and low spots also. this car we want 100% perfect so there will be were guessing 80-100hrs of body work and all to get it right and painted. Not 40 like they claim.
Old 11-08-2012, 05:48 PM
o here is a sneak peak at what it will look like. it will be a black but it will have pearl in it, and some red peal stripes, ditch the big snorkel and the pass side roll bar. but there is my wheels photoshop on it also.
Old 11-08-2012, 05:49 PM
Tonight after i get this ZO6 tuned that we are finishing a stg6 kit on i am hoping to get the rad hoses on, the water pump mounted and start on the engine wiring
Old 11-08-2012, 06:04 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
Nice,
I always liked the Cobras.
Ultralight plus big power & you have a real nice combination.
Did I see an A/C compressor on the engine?
Nice addition there.
Old 11-08-2012, 07:02 PM
silverWS.6's Avatar
That is going to be a monster!!! Very nice!
Old 11-08-2012, 07:09 PM
superdave84's Avatar
Going to be awesome....but absolutely terrifying to drive at full throttle
Old 11-08-2012, 08:13 PM
Daz
Daz's Avatar
Nice ! I'm not loving the scoop on the hood but nice !!!
Old 11-08-2012, 08:30 PM
gofastwclass's Avatar
Classic looks with modern power and brakes. cool.
Old 11-08-2012, 09:50 PM
Rocketrod's Avatar
Incredible build!!!
Old 11-09-2012, 11:38 AM
NSSANE02's Avatar
Amazing build! That's my dream combo
Quick Reply: Twin Turbo LS powered AC COBRA Kit Car Build
