Blip/Spike of KR at initial start-up of motor?
As a heads up im currently running a 98 pcm with a 01 Lq4 motor. I currently have (hopefully) all of the KR tables and sensitivity to be similar to the 01-02 ls1 setup in hp tuners. with that said, I currently am seeing KR spike whenever I fire up the car. It can be anywhere from 3*-9* for a split second. Is this normal? seems to occur at around 900RPMs and the timing i believe is ~25-26* but when i get the KR spike it drops to 19* then once it disappears timing is back to ranging around 25-26*.
