FS: Built LS7 complete Fast 102mm intake to wet sump oiling. 24x ready for your Fbody
Category: Engine - Complete Motors
Price: $15000
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): IN
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
The engine specs are as follows.
GM LS7 engine block with 4.130 bore
GM LS7 crank with 24x reluctor wheel, machined to standard length for wet sump oiling
GM LS7 titaniaum connecting rods
Katech rod bolts
ARP main studs
Wiseco 2618 forged dome pistons (11.9:1 compresson with stock chambers, 13.3:1 with optional heads listed below)
Wiseco rings
C5R timing set
Ported GM DOD oil pump
GM LS2 oil pan (I can swap on an F-body pan and pickup tube)
BTR custom ground cam (255/262 .670/.670 115LSA)
LS7 lifters
Comp Cams push rods
GM stock LS7 rockers with Comp Cams trunion upgrade kit
BTR valve springs and titanium retainers
ARP head studs
I have 2 sets of heads available for this engine.
1st set LME ported and milled for 13.3:1 compression for E85 LS7 heads with GM titanium intake valves and Inconel exhaust valves
2nd set LPE 660hp package ported LS7 heads with GM titanium intake valves and Stainless exhaust valves stock chambers for 11.9:1 compression.
FAST 102mm intake ported by Vengeance Racing
Nick Williams 102mm billet throttle body
GM LS3 fuel rail
42 or 60lb injectors
Since this engine is apart and being refreshed to sell I will assemble it with either set of heads at no added cost. If you wish to run it on E85 I'll have it assembled with the small chamber LME heads. If you wish to run pump gas I will assemble it with the LPE stock chamber heads.
I am asking $15,000.00 or best offer for this engine. The $15,000.00 will include shipping to anywhere in the contiguous united states.
