will 94 lt1 work with 95 wiring harness?
x2 it should have all the same OBDI connectors. I think the only differnece was the 95' had the 16pin OBD2 connector but still ran OBDI everything else.
Safe to assume that you meant to say the donor is a 94 TA?
I believe the opti extension harness is different.
Honestly though I would swap the 95 opti/timing cover onto the 94 engine. I am not sure if the 93 upper timing gear fits with the vented opti, if it doesn't go ahead and swap that too. Not that big a deal and gives you a chance to change all the timing cover seals.
