Foxbody Swap Crossmember Information (LSx) The CHEAP and Easy way
Old 11-13-2012, 05:29 PM
Speedy911's Avatar
Default Foxbody Swap Crossmember Information (LSx) The CHEAP and Easy way
This is the transmission crossmember from a 4 Cylinder Foxbody Mustang, it has bolt on brackets. This makes adjusting or re-positioning the transmission crossmember very simple. It measures about 29.5" from end to end including the brackets and may be used on other vehicles.
Mounting it is very easy. Simply drill a hole in the "frame/subframe" and bolt it in. These brackets can be later welded in for additional strength.
This is a very cheap alternative to AJE crossmember and the AJE does not fit in early cars because of the smaller mounts/bushings.
No welding!
Old 11-17-2012, 09:11 PM
TxFireman1972's Avatar
How does it workout for exhaust clearance?
Old 11-18-2012, 12:11 PM
Speedy911's Avatar
Not sure! I have not checked yet but I don't plan on running an exhaust as of yet. Maybe a downpipe out the driver or passenger side fender.
Regardless there should be enough clearance to navigate a 3" or 3.5" pipe to the back of the car.
Old 11-18-2012, 12:29 PM
Probably good for a single exhaust like a turbo. Dual exhaust would be tough.
Old 11-18-2012, 12:33 PM
Speedy911's Avatar
I'll snap some pictures when I get back out there.
Old 11-19-2012, 07:18 PM
1bad03snake's Avatar
I used a V8 mustang xmember on my car. You dog leg the trans mount holes and grind the spot welds and it fits perfect I'm using a T5 trans mount also
Old 11-19-2012, 07:49 PM
Yeah I have the one off of my car I'm going to try. Need to look into the mount location of the 4L60E compared to the TH350
Quick Reply: Foxbody Swap Crossmember Information (LSx) The CHEAP and Easy way
