foxbody swap question on guages
alright im about to undertake my first swap on a 93 notch that i just picked up and got a question.is there a way to make the stock 4 cyl tach work?
everything else i think i have figured out and just need fittings for the sensors.i do have access to my fbody cluster as well if any one has info on using that along with pics would be awesome as well.im just not sure how that would look.
thanks
thanks
From what I hear the fbody gauge cluster is almost a bolt in. Very little modification for that year of mustang. I dont know this from personal experience, just what I have read and heard. This may be the easiest route for you to go. Plus you get to utilize most all of the sensors including the oil level sensor.
I'm trying it now in my 99, not a bolt in for me unfortunately. If it works ill post pics but I don't think it will. It's way too big and I don't believe I can cut enough without affecting the circuit board
here is one in a fox.
http://www.popularhotrodding.com/tec...t/viewall.html
here is a thread about the newer mustangs john. maybe you can contact him about what he did.
https://ls1tech.com/forums/conversio...ster-help.html
hmm i may have to do the guage swap.but i think the open edges will **** me off.from what i read the ls1 pcm tack output is the same as a 4cyl so it may work just fine
thanks guys
thanks guys
I don't think so I actually cut too much off the bottom on the temp side a knicked the circuit board a bit. Hopefully I didn't kill it. I also had to cut the bottom support out of my dash and its still crammed in thier
