L92 heads on LQ4
Old 11-23-2012, 08:32 AM
kainedogg's Avatar
Talking L92 heads on LQ4
I plan to do an L92 swap on my '00 LQ4 next spring but have read that aside from the heads, intake, throttle body, fuel rail and injectors that I may need to change the truck accessory drive as well. Any input?
Old 11-23-2012, 08:38 AM
Tainted's Avatar
Just depends on what vehicle you have it in. Cars cant use truck style setup because of hood clearance.
Old 11-23-2012, 09:00 AM
wildcamaro's Avatar
I thought that l92 used the same truck accessories, but if your are just changing the top end I would think you could use the current accessories you have
Old 11-25-2012, 12:06 PM
kainedogg's Avatar
It's presently in an '84 C10
Old 11-25-2012, 02:33 PM
Received 3,370 Likes on 2,086 Posts
Newer cars with lower hood line, have clearance issues. Older cars, like mine, can run the truck accessories with room to spare. No worries K-dogg, the accessory holes in all the LS series heads are the same.
Old 03-30-2013, 01:49 AM
kainedogg's Avatar
Late resposne on my parts but thanks brother. What about the truck water pump on the lq4?
Quick Reply: L92 heads on LQ4
