Did i purchase the correct ring & pinion gear?
Old 11-24-2012, 12:48 PM
04rev600's Avatar
Default Did i purchase the correct ring & pinion gear?
my car started off with 2.73 so im guessing its the 2 series carrier. so i purchased richmond 4.10 7.624 10 bolt 2 series. Is this correct? And now that i will have the rear end pulled out should i replace anything besides gears, fluid and gaskit? Thanks
Old 11-24-2012, 12:53 PM
04rev600's Avatar
http://www.summitracing.com/parts/rmg-49-0009-1
Old 11-24-2012, 05:07 PM
01ssreda4's Avatar
Yes your's is a 2 series.
Old 11-25-2012, 02:20 PM
04rev600's Avatar
And were does it say exactly what gears came in the car? the guy i bought from says 2.73 but just want to make sure. i looked on the door but stickers are a little faded but if someone told me what code im supposed to be looking for im sure i can find something.
Thanks
Carter
Old 11-25-2012, 07:07 PM
96lt4c4's Avatar
Originally Posted by 04rev600
and were does it say exactly what gears came in the car? The guy i bought from says 2.73 but just want to make sure. I looked on the door but stickers are a little faded but if someone told me what code im supposed to be looking for im sure i can find something.
Thanks
carter
gu2 axle rear, 2.73 ratio
gu5 axle rear, 3.23 ratio
gu6 axle rear, 3.42 ratio
Old 11-25-2012, 07:19 PM
k0261886's Avatar
Or get the back end up in the air and turn the driveshaft and count how many times the rear tires turn per driveshaft revolution
Old 11-25-2012, 08:51 PM
04rev600's Avatar
Good point....
Quick Reply: Did i purchase the correct ring & pinion gear?
