cam codes with inop tach, calling mr whitebird00
I recently swapped a 99 ls1 t56 into my 01 v6 camaro. The motor cranks, at times will just crank, sometimes backfire, and sometimes fire up. Throwing a p0343 cam voltage high and p0344 cam voltage low. I swapped the cam sensor last night with another one a friend ad laying around. Now it is only throwing 0343. I've read about the swapping of the outer wires on the cam connector but everything I've read said for ls2s. I've also been told about some harness extension for the ls1 cam sensor which my harness does not have. The connector has been apart from harness sometime in its life and has been butt connected back together. I'm not sure if the sensor I swapped is also bad? The tach works with the tech 2 when the sweep is commanded. I've looked through pages of google searching and on this site looking for the cluster pin out to track continuity between the Pcm and tach but no luck finding a diagram. Any information anybody can provide would be greatly appreciated.
