FS: Aeromotive Adjustable Fuel Pressure Regulator
Category: Accessories
Price: $100
Location (State): PA
Item Condition: Used
LS Engine?: Fits LS Engine
Aeromotive adjustable fuel pressure regulator with boost/vac reference. From their website:
Big performance in a small package. The Compact EFI Regulator is designed for applications producing up to 1,000 HP where space is at a premium. Ideal for EFI fuel delivery systems that are limited to one regulator inlet port.
• Adjustable from 30-70 PSI.
• Equipped with removable AN-6 male fittings for inlet and outlet ports, eliminates the need to buy additional fittings and O-rings.
• Dedicated, 1/8” NPT gauge port located opposite the side inlet.
• Fuel pressure rises on a 1:1 ratio when referencing boost.
This regulator performed flawlessly on my set-up for about 4k miles. The condition is as close to new as you are going to find, not even a scratch on it. -6AN Fittings are included however the plug for the fuel pressure gauge port is not. Not an issue if you plan to install a gauge! If not, the 1/8” NPT gauge port will need a plug. You can buy at places like Summit for about $2, or go to Home Depot and buy a brass plug for $0.75. I will give a look as I may have one laying around.
$100.00 Shipped in the lower 48.
