68 Camaro LS1 6spd
68 Camaro LS1 6spd
Last edited by DocHall; 11-29-2012 at 09:51 AM. Reason: learning how to insert link
Questions:
Are you using the stock sub or aftermarket?
Is that a 1st gen radiator? What fans did you use?
How did you run your fuel system?
Did you relocate your battery to the trunk to run the CAI?
What did you do to make the stock console work?
If you couldn't guess, I am just starting the same swap on my 68 Camaro. I am thinking about using the original fans off the 99 TA the engine came from but I would have to fab custom brackets to make it work.
