02 Firebird LS1 swap - No power to Fuel Pump
The pcm pulses the ground for the fuel pump when you turn the key om,Green wire with white strip.That's what I would check out first.If not,check all the grounds on the back of the head and make sure the motor is grounded correctly to the frame.Good luck...
