65 Mustang build thread- 404,Twins,Caged,Tubbed,ETC. UPDATE 10/9
Old 12-01-2012, 07:46 PM
baggins's Avatar
Default 65 Mustang build thread- 404,Twins,Caged,Tubbed,ETC. UPDATE 10/9
Ok so i have a thread in the conversions area but I think its a little more fitting over here.
The car has been together and apart multiple times over the last 7 years. Well hopefully this is the last time I'll have to do any fabwork on it. Work is being done at a shop locally that I used to work for. Goals for the car are to hit 1000rw, knockdown a 8.99 or better pass and be able to drive it anywhere. I mainly want the car for cruising and freeway roll races. Heres the breakdown-
Chassis
Aje front k member and suspension with some mods
Caged
Backhalved
Narrowed 8.8
Moser wavetrac posi or spool (still up in air)
33 spline axles
18x9/10 with 315 Hoosier DRs out back (street trim)
Cobra disc brakes on all 4 corners
Engine and drivetrain
404ci iron block
Diamond piston
Lunati pro series crank
Luntai billet i beams
LSA cylinder heads
Victor jr manifold
6061 elbow
FAST 102 TB
120lb bosch injectors (need)
Custom cam (need)
BT spring kit (need)
studded throughout
Either going to run a 48l0e or th400
I bought a Forced Inductions GT91 last week and should be getting it on Tuesday. As soon as the chassis fabrication is done I'll start working on putting the turbo kit together.
Some pics
cage pogress
Anyways thats the just of it for now-
Old 12-01-2012, 07:54 PM
JoeyGC5's Avatar
Subscribed to a cool project
Old 12-02-2012, 10:15 AM
trans2000am's Avatar
looks good man!!!
Old 12-02-2012, 06:24 PM
baggins's Avatar
Trans2000- were you able to find any paperwork on the turbo?
Old 12-02-2012, 07:01 PM
IH8FORD's Avatar
Nice project. What do you the weight of the car will be when its done?
Old 12-02-2012, 07:36 PM
No i will try to give force inductions a call tomorrow to look up my info
Old 12-02-2012, 08:59 PM
baggins's Avatar
Thanks that would be awesome-
Old 12-02-2012, 09:02 PM
baggins's Avatar
As long as its under 3000 lbs. Ill be happy. Stock weight is around 2650-
Old 12-03-2012, 06:29 AM
JAX04's Avatar
Sub'd, great project!
Old 12-03-2012, 09:03 PM
baggins's Avatar
Old 12-03-2012, 09:22 PM
glad to see you got the turbo, I called and left a voicemail today
Old 12-03-2012, 09:47 PM
overhere's Avatar
Could u take some overall measurements of the turbo?
Cant wait to see the end result.
Old 12-05-2012, 06:28 PM
baggins's Avatar
Getting ready to cut out the front aprons and shock towers. Adding a motor plate and setting the engine back 2". Tunnels gotta be modified to fit what will either be a 4l80e or th400
Old 01-30-2013, 02:14 AM
baggins's Avatar
Not a whole lot going on as of late but have picked up some new parts
Also a 31x12x4 intercooler
Old 01-31-2013, 12:19 AM
LSx64Chevelle's Avatar
Did you just buy that th400. I saw it listed on craigslist in manteca. Btw, this is going to be one BAD car. What kind of timeline are you shooting for to see that 1000 hp on a dyno?
Old 01-31-2013, 12:34 AM
baggins's Avatar
Yep, picked it up last weekend... I'm hoping to have the car drive able by June, it won't be done but I at least hope to have it tuned and drivable by then. How do you like synergy's tuning?
Old 01-31-2013, 07:44 AM
LS1Tech Sponsor
hellbents10's Avatar
I have to keep an eye on this, looks like it has the potential to be an epic build!
Old 01-31-2013, 04:08 PM
baggins's Avatar
Anyone have a hookup on Holley products? Im looking to get a hi ram and the HP efi fuel injection setup... any help appreciated
Old 01-31-2013, 04:44 PM
SKULL's Avatar
whats wrong with that intake setup you had posted earlier? and that guage cluster is AW SOME
Old 01-31-2013, 07:58 PM
k_cash1432's Avatar
Poor distrabution in the back cylinders with FI and that elbow was terriable flow with the sharp angle going into the intake...
Quick Reply: 65 Mustang build thread- 404,Twins,Caged,Tubbed,ETC. UPDATE 10/9
