2002 trans am backfireing and cutting out
Is it backfiring from the exhaust? A way to fix this backfiring usually involves checking for vacuum leaks, changing the airflow sensor, oxygen sensor, or fuel filter to ensure the fuel system is functioning properly. Because backfire occurs when there is an imbalance in the air to fuel ratio required for your vehicle to operate properly. If the fuel mixture is too lean (not enough fuel) you may have a backfire in the intake, or too rich (too much fuel) you may get a backfire out of the exhaust system. Most backfires are easily repaired by correcting the imbalance and providing a greater or lesser percentage of fuel to the mixture.
