Window regulator problems?
After searching and reading all the threads regarding power window problems I'm still not seeing anyone with this condition on a fourth gen f body. Replaced motors 8 years ago and they finally got too slow for me so I decided to replace them. During replacement I noticed a lot of back and forward movement in the glass so I looked everything over and also adjusted everything for a nice seal. Still can't get the front/back movement out of it. After re adjusting and looking things over multiple times I finally noticed the arms are loose where they mount to the regulator with that square looking rivet. Has anyone ever encountered this? Guessing I need new regulators? There are no broken tracks or rollers, rivets are not loose, everything is adjusted nice and properly lubed.
Save the manuals!
If your window moves forward/backward and will shut all the way, then you probably have this common problem: https://ls1tech.com/forums/general-m...dow-guide.html
Save the manuals!
It would take a nuclear explosion to damage this. Even if it was "loose", its a pin point so you wouldn't have any movement.
You should next check for this other common problem before popping out the regulator: https://ls1tech.com/forums/general-m...-included.html
I have looked at a lot of threads. That one included before I decided to post a thread of my own. The rivets are not loose,the holes are not elongated and there has not been any handywork done. Car is 16 years old,and I have owned it for the last twelve. Can't expect this stuff to last forever. Unfortunately I think they are just wore out and will require replacement. I'll put some new ones in and update the results when complete.
