1999 Camaro Left Front Indicator Bulb Problem?
The Bulb on my Front Left Side Indicator (The One with the Orange Lens, See Below) keeps going out. It last one week before it goes out. If I look at the wire harness it was repaired with electrical tape. How can I find out where the short is? Or can I replace it? Does anyone know where I can get just the part of the harness?
pep boys sells the harness. check the contacts in the socket and see if they are corroded. that was the problem on my ws6 because the lamp filled with water in the rain. drilled small holes and fixed both lights.
