Biggest tires on 99 camaro
Old 12-07-2012, 06:04 AM
Suprfast's Avatar
Default Biggest tires on 99 camaro
What's biggest tires on a 99 Camaro drag radial.
Old 12-07-2012, 07:34 AM
Asian LSX's Avatar
What size wheel are you planning on running? Also, are you willing to take a hammer and beat the inner fenders to fit a tire or just bolt it on and go? If you search you should find a ton of threads covering this with lots of good info and pictures to help you.
Old 12-07-2012, 11:42 AM
Jefro6996's Avatar
Most guys easily fit a 315 DR by beating in on the inner fender and rolling the feneer lip if you are lowered. Some people fit 335 and 345 drag radials without a minitub but they stick out way too far IMHO. I run a 315 DR and im lowered and it fits perfect. Ive also ran a 325 which easily fit, but I did have to cut off the bumpstop so I didnt have to run a spacer. I hate when wheels/tires stick out too far.
Old 12-07-2012, 12:41 PM
Camaro396's Avatar
Old 12-07-2012, 11:34 PM
veinharvest's Avatar
not drag radials, but I run hoosier A6's 335/35/17 rear 315/35/17 fronts.
Quick Reply: Biggest tires on 99 camaro
